Thank youSome very nice work has been done there, shows the ability of the overhead router but would a spindle do the same ?
This is as near identical to the one I use, looks to be just a later edition with the modern Wadkin colouring and some other minor details.If anybody fancies one this could be a bargain, but not much time left.
Brian
Could you elaborate a little on the process used for making this, order of operations, what joints and fixing methods you used? very impressive dude,
Thanks for the kind words.Could you elaborate a little on the process used for making this, order of operations, what joints and fixing methods you used? very impressive dude,
thanks
hi I'm just reading through this and am struggling to understand how the jig keeps the work square I assumed the work would try and spin as it went through the cutter any chance you could shoe me somehow hoe this works ? maybe a little sketch or something would be greatly appreciated. many thanks JamesNow it’s all set and I am happy, I can dog Into all the stiles, 4 are going in one direction 4 are going the other (we call this handing) means no more than 4 are going left and 4 are going right and when you pair them together to make the door they are both going in same direction as they are opposites to each other. No need for two jigs though you simply flip the ply over and Roberts your dads brother!
I mark them all out from my rod so I have a reference and then it’s insert and go, just sliding it up to the mark every cut. I cramp up every time to avoid slippage and break out. Once I machine all the way through I lift the head gear up out the way and return the work back through ready for resetting, I don’t want to back my work up through the cutter again on the reverse slide as it may widen my groove ever so slightly and fluff up my joint.
Ready to go
Guard In place, pin up through the jig, cramped up to avoid tear out, push and go.
You get the idea from this shot at the repetition and accuracy and how clean it is. It takes minutes to get this done it’s a fantastic machine.
One jig and a few hours work. I have loads of stuff I can load up here if interested! I’ll have a dig about in the archives for some interesting bits
Good bit of 'preach' advice. I guess we're nearly all guilty of doing that, without thinking, at some time or other.Fab info thanks, I've seen them often going for some pretty low prices etc and thought a little about how they worked but never seen in action. Too big for my little shop, but with a house move on the horizon I could end up with more space for more machines!
Warning preach incoming!
No intent to upset but the breath you take after lifting your dust mask to blow off the dust is likely undoing any benefit of the mask, you have your face in the dust zone by the work piece and are taking a nice hard breath in. Preach over!
