Packing up a PVCu door
RossJarvis
20 Aug 2013
Petersfield, Hampshire
Okay, apologies that it's not strictly woodwork, but..... I've volunteered to fit a door for the church office, no pay and limited budget. There'll be a big gap under the ally threshold, which is for disabled access and below path level, meaning it'll be fairly damp. Can I pack up on oak blocks or do I need plastic. Do I need DPC round a PVCu frame with Ally threshold.
Any help gratefully received :D
I'd always pack with plastic, no chance of rotting, foam fill round the frame after fixing & ensuring the door functions properly, no need for DPC.
Be careful how you fix it: PVCu has usually a steel core (if any) and you mention an aluminium threshold strip: It ought to mean the aly corrodes sacrificially, but in my experience, the coatings on screws (zinc, etc.) cause (un)funny corrosion reactions.
Can you arrange drainhole(s) for the threshold trough? Even a bit of buried blue water pipe would probably help. The idea being not having to do it again in a few years time.
Go with Doug's advice.
Thanks for the help guys.
Normally I'd use plastic packers but there'll be a big gap, about 30mm high by 140mm deep and 1000mm across, the packers I've used haven't locked together and I was wondering a bit about stability (toppling). As I've got a big lump of oak I was just wondering whether this might do as I could fill the whole gap.
Ross
30mm x 140mm gap? I'd fit a reinforced uPVC 150mm cill unless it's an Exitex threshold (in which case they don't sit on cills with a back upstand).
