MorrisWoodman12
I have an old Record DMP106 planer/thicknesser that has just given it's thicknesser drive belt leave to go on holiday. Every time I go to use it the drive belt comes off the pulley so the thicknesser feed bars stop rotating. The DMP106 looks to be identical to the Record PT260 and the Elektra Beckum HC260. Everything under the cover looks to be in reasonable condition especially considering the machine was made in 1989. The bearings of the pulley and the cutter block appear to be OK with only minimal play and the belt isn't slack - it needs a bit of persuasion to go back on. Does anyone have any suggestions as to the likely cause please?
Regards. Martin
Regards. Martin
