Shultzy
I have a Record C26+ combi which has 3 2hp Class 1 induction motors. A month ago after using the planer for about 15mins continuously there was a bit of a burning rubber smell when I switched it off. On further examination I found the planer motor was very hot and the so was the belt. I contacted Record who said "they do get hot" but agreed to come out with a new motor which they did.
Over last weekend I planed a large amount of pine using it for about 30 mins continuously. The motor was so hot that the bolts holding it under the thicknessing table were too hot to touch.
As this is the second motor I thought I'd ask the forum for advice to see if it is normal, or there is something else that's causing it to overheat, before contacting Record.
