This is a slow burning project and is only at the idea stage at the moment. It will be after lockdown ends because I don't have the timber. Documenting it here helps me work thorough it in my mind, probably helped by comments saying "why are you doing that you silly person, of course it won't work"!
We need an outside table to be able to eat from in the summer (both days). I really like live edged tables so my plan is to use a wide board if oak or chestnut if I can get one. I would think it would finish at somewhere between 35mm and 40mm but the slab isn't bought yet. I wouldn't want one with too many features/holes/inclusions etc, but if there was a split or two, I would reinforce these with subtle butterflies/dovetails. No resin.
Legs to be decided, but concept is https://www.thehairpinlegcompany.co.uk/ ... on-v-frame to avoid wood/ground contact. They would be fixed to allow movement. I haven't looked at the prices elsewhere but this was an easy site to link to.
Finish would probably be tung oil. I know it isn't UV resistant. Worst case it needs sanding once a year and reapplying, but it is a 1800*650mm flat surface so it wouldn't be a long task. I don't mind it silvering, I am aiming more for some stain resistance and a finish that would give a wipeable surface. It would probably be covered when not in use.
Seating would be a couple of benches, using similar principles.
So for some questions.
Any reason why this wouldn't work? I am nervous that I haven't seen many live edge outdoor tables?
Any other durable timbers that would be suitable, preferably native but happy to include some of the estate grown specimen trees, sequoia, wellingtonia etc? Are those two even suitable?
Mark
Mark
