The coffee table that I refurbished for my mother finally got delivered after 18 months of covid delays, so we are without a place to put our cold beer/prosecco whilst enjoying the garden.
I had seen a simple slatted bench design by The Wood Whisperer which I was confident fell comfortably within my abilities. You'll have to read to the end to judge that for yourself . I wanted to shorten the bench a little and I would be using Sapelle with loose tenon joinery, so I would also need to build a loose tenon jig.
My first job was to audit my Sapelle stock to see whether I would need to make a trip to the lumber yard.
By shortening the bench design to 12 slats instead of the 17 in the design, I could avoid the lumber yard. It has wiped out my stock, so a trip is inevitable I guess.
The rough sawn stock that I had been avoiding milling (due to not having a jointer) would be needed, and fortunately my FIL has passed down his trusty old Myford planer, which with only very minor tweaking (and learning!) I was able to get good enough surfaces out of. The blades need sharpening for sure, but "flat enough" was good enough in this case.
With the stock milled and rough cut, I moved on to building the loose tenon jig.
