Simon_M
I'm looking at trying outboard turning e.g. putting the headstock in the middle of the lathe bed facing forwards and using a freestanding tool rest to turn (bigger than the normal swing) bowls.
I was going to make one from 2x4 timber (12" wide frame and required height) and a 3/4" plywood foot. Has anyone tried this and what would you suggest?
Or I could move it towards the LHS and add a brace to the extension mount points. There might be advantages for either?
I looked at videos and it's using either a bed extension at right-angles or (surprisingly) a free standing rest as well. I was going to try it on a small e.g. 8" bowl before going bigger.
On an AT1628VS, the bed extension can also be mounted lower on the RH leg, but I don't really have the space to try this. BTW, There are no mounting points to put it in the middle of the bed.
