David C
In Memorium
I insist that my students work out correct feed direction for every different form of cut befor switching machine on.
Slow but hopefully safe.
David C
David C
Shultzy":bq3y9r1l said:Surely the easiest way is to cut the right hand side of the groove using a smaller cutter than the finished size of the slot, then move the fence over and cut the left hand side of the groove. This way the wood is moved from right to left as normal.
brianhabby":nac8g4ay said:The reason I was flipping the piece was to ensure the groove would be centred, moving the fence would not ensure this.
Brian
Shultzy":36lj55eo said:brianhabby":36lj55eo said:The reason I was flipping the piece was to ensure the groove would be centred, moving the fence would not ensure this.
Brian
In that case Brian cut the left-hand side of the groove first and the turn it around. That makes sure the cutter is cutting in the right direction.
