OSB
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
Has anyone used OSB outside for any length of time?
If so what did you paint it with and were you happy with the outcome?
Artie, the old hardware yard behind Strandtown Police Station had O.S.B. walls on its shed for more years than I can remember. Wilbur and the gang did NOT paint or treat it in any way and it was still going strong when he sold up and they built those ghastly yuppie flats there.
I’d personally not use osb externally unless I had no choice for whatever reason. I can only imagine that the quality of osb years ago mentioned by @SammyQ was vastly different from today’s standards. Even the ply they use to fence off building sights and empty buildings does last long . If I did have to use it outside then outdoor varnish or bitumen or other oil based exterior paint to give it a fighting chance.. just my opinion .
I'd trust OSB over modern ply (unless an expensive true marine grade) any day for durability - much higher glue content and the way it is made means it is more impregnated not just sitting between layers.
That does not stop it being rough as a badgers wotsit.
Yes, I mean OSB3. Haven't come across 2 for a long time, but not looking for it. I guess there must be a OSB1 as well, never seen that.
I was aware of different grades but didn’t know about the glue content, I’m not a osb fan but hear what you say . Agree about most plywood though..
I'm not a fan of it either, it's so rough. But got to give it some grudging credit where due for its better qualities. And now its back down to reasonable prices it's back to being a useful budget option for rough (or hidden) purposes!
Tbh i seam to recall a few years back an option of osb had a resin coat to it or a heavy duty acrylic paint of some type , not seen it since though but I remember saying to a friend- I wonder how long that would last outside ..
Built my "Man Cave" with OSB3, breathable membrane, roofing battens, then clad over the top. In much the same way as all the loft extensions around here have been constructed. That was 13 years ago. Still bone dry and rot free.
What cladding did you use?
Hhmmm..I'm thinking backs of wall-hung cupboards etc instead of ply...(Saving SLW tokens et cetera. )
SLW?
Systematic Lumpsum Withdrawal??
I've found OSB to be unexpectedly robust, unpainted, outdoors and exposed to the elements. For example, a part sheet on top of a cement mixer to protect from the weather - 2 years on its still fully intact and doing the job perfectly.
I've extended to the rear of the house with a modern flat roof extension. The roof is GRP and the required spec for the deck was T&G OSB and specifically NOT ply, even marine ply. This is because the ply has a tendency to delaminate and OSB is considered to be more stable.
For a DIYable flat roof I consider this unbeatable.
20 years ago I built a shed out of the bitumen coated osb that was then available from Wickes. Lasted well only took it don when we built an extension
