Dovetaildave
Its a Biggie, biggest I've ever made!... L 1220 x H 1220 x D 500. seven graduated drawers.
Wife wants it "out of my way" as space is tight in this one bed flat, so a bit of a rush as well :roll: .
Drawers are assembled and stored outside in communal stairwell(not popular with the council). Top base, sides and back in the bedroom. work surface is the kitchen table for measuring and fitting runners if still flat packed and veneering interior.
Will have to do all the work in the bedroom as it will be to large/heavy to move around
I can't fit the steel runners to the sides till I can decide how it's to be veneered
Generally is seems to be;
Option A the Joints have to assembled, then exterior veneered and finally attach draw runners.
Option B veneered the interior,attach draw runners, joint, veneer outside.
Materials used;
Carcass Ply18mm, birch faced top and base.
Drawers with overlay fronts 12mm ply, cheaper constructional grade.
Steel runners, heavy duty 40 KG, 500mm length.
Jointing;
The Carcass is dovetailed and back is 12mm ply rebated and screwed. I have dry assembled it, now its flat packed.
I have experience in;
Scotch/hammer and have used cascamite (UF) on smaller bedside cabinets that I could clamp/press/heavy weight.
I can only veneer the exterior after it has been joined and back is screwed on, thus making the interior difficult to access or work on horizontally.
I will use;
Birdseye maple (three/four leaves bookmatched).
Indian rosewood crossbanding and edging.
Polish with mylands transparent and special pale shellac.
Questions;
1, Can I get away with hammer veneering just the outside (18mm ply), avoiding contra/balance veneering if the item is glued and back screwed together making it a little more stable?
2, If I change to contact adhesive can I veneer just the outside? if so any advice on the method when taped and book matched?
3, If I have to hammer/contra veneer the insides, can I wait a day before assembling the precut dovetails and veneering the exterior or will I end up with four very large and expensive pringles? Must I do interior veneering then assemble it, then bookmatch the exterior all in one day :? ?
4, Has anyone used two methods of veneering of both faces of a ply sheet, could that be an option?
5, Most importantly; Anything I haven't asked but will encounter as I rush at this before school starts back again
Thanks,
Dave
Time is against me guys....I have to start on Sunday morning or begin divorce proceedings.
Materials used;
Jointing;
I will use;
Questions;
Thanks,
Dave
