pgrbff
Can anyone suggest a free and easy to use program to open a dwg file?
I don't want to make any changes, just view the drawing.
I have Premiere albeit CS5, I'll try illustrator, thanks.If you could supply the file I think I can open it in illustrator and convert it to a different file format. Not sure if that would help?
Autodesk Fusion 360 is free for students/hobbyists - you should be able to work out how to view/print easily enough.Can anyone suggest a free and easy to use program to open a dwg file?
