Fromey
I'm making a six-board chest to help store tools in the shed and double as a saw horse. Yesterday I was gluing up the panel for the bottom of the chest and discovered this morning that I accidentally glued the two boards with the rings in the same orientation. This board is going to be fitted into the end boards via a dado (and I'll probably toenail them in as well).
Do you think this will be sufficient to prevent the panel from warping over time?
Or, should I rip the panel down, clean up the edges and re-glue it in the correct orientation?
