Hudson Carpentry
Well after needing an adjustable stand for my projector, I thought up a design thats basic and quick to make but while I was cutting the pieces I thought what a simple project this would make for someone thats new to wood working. Its cheap, useful around the workshop and gives you a change to try a lap joint.
Its basically a small adjustable platform that would be useful around the workshop to support material while at machines and with a few mods it could be a tool trolley or even a platform to hold your work up while you spray/paint/finish it.
All you need material wise is MDF, 12mm or thicker. Although I have used a bit of redwood also. A bolt, 2 penny washers and wing nut (in my case 2 wing nuts and some threaded bar).
If you follow my sizes then you will need a M8 bolt or M8 threaded rod around 75mm long. If you ask me, using threaded rod and 2 wing nuts is better as it prevents the possibly of the bolt head from just spinning while trying to tighten to wing nut. Also all these sizes are for 12mm MDF, if you want to use a thicker material then you will need add and subtract the difference where necessary.
For my projector I needed a total height of around 130cm so I cut all lengths to 76cm. Ok no I didn't that was just the length of the piece of crap I found to make this stand from :lol: For workshop use lengths of 55-65cm Would be better.
Widths
2x 26mm
2x 50mm
2x 51mm
2x 75mm
Grab the 26mm's and the 50mm's, some wood glue, a brad nailer if your lucky enough to have one with 30mm brads, drill with 3-4mm wood bit, some 4x30mm screws, a counter sink and No. 2 Posidrive screwdriver (or bit for drill/driver). We are going to make these into a square box section.
The wider lengths fit over the ends of the 26mm lengths. Apply the glue, line up the ends and use a few brads to hold the pieces together while you drill pilot holes and counter sink for the screws. If you don't have a brad nailer you could use panel pins, clamps or just wing it (hammer) .
Sorry about the blury imagin, it looked fine on the camera screen ...... honest
Do the same to all 4 pieces till you have your square box section 50x50mm. Choose which ever is the poorly aligned end
if one. Turn the piece so that one of the wider lengths is facing up, measure 70mm up from the end and 25mm in from the side marking with a pencil. Use a 8mm wood bit to drill a hole through your mark but only go through the one side. Turn over and do the same to the opposite side.
The reason you don't do both holes in one is for accuracy. With the 26mm void you may rock the drill unaware making the other hole a few mm off and at an angle.
Push your rod through to make sure its a good fit.
The next part we need to make a slot for the threaded bar to run in. The best way would have been a router table or even a handhold router but as I couldn't be bothered to set either up or even the bandsaw I used a table saw, drill and hand saw. Thinking about it if you wanted to practice cutting straight lines with a saw you could cut these slots by hand. As I used a table saw ill talk you through this way.
Take the 2 lengths at 75mm wide. Select an end and measure 70mm up and .... yes you guessed it .... 37.5mm in from the side. Use the 8mm drill the holes. If you have one a 10mm would be better. I do but didn't because I couldn't be bothered to change bits #-o see a pattern? :roll: :lol: Set the TS fence to 32 mm and run the length into the blade starting at the opposite end to your hole. Stop when you are 2 inch away from the hole. Reason being is the round blade under the piece will cut further then you can see. Flip the length repeat.
After finishing the cut with a hand saw you should have something like this:
Once you have done the other length make these and the 51mm bits into a box section the same way as the other. The reason we cut the larger lengths 1mm larger then required is to leave a little room for slight misalignment and a smooth non stiff action.
You might be tempted at this stage to slide the smaller box length into the larger one. Please do but don't force it if its stiff and do not leave it inside for long or they will never part again from access glue. If its stiff just sand the smaller box section down a little.
You should now have:
Anyhow im up to the attachment limit (i think) so ill continue in the next post.
Widths
2x 26mm
2x 50mm
2x 51mm
2x 75mm
![1.jpg 1.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/2/2247-1.jpg)
![2.jpg 2.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/2/2248-2.jpg)
![3.jpg 3.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/2/2249-3.jpg)
![4.jpg 4.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/2/2250-4.jpg)
![5.jpg 5.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/2/2251-5.jpg)
