Steve Maskery
OK, dumb question time.
If the existing pipe is buried and you cut out a section. How do you get your Tee-piece in? I would have thought that you need to be able to separate the two old halves, insert the T, then close the two halve together again. How can you do that if the pipes are buried solid?
Clearly it is possible, as this must be done every day, but I'm a bit ignorant of these things and would like to be heducated.
S
S
