devonwoody
Thanks Jim,
devonwoody":255omngg said:Thanks Jim, it will be an excuse to make a box. :wink:
9fingers":kcoh2qtn said:devonwoody":kcoh2qtn said:Thanks Jim, it will be an excuse to make a box. :wink:
Don't forget to earth the wooden box DW :lol: :lol:
Bob
devonwoody":2pe6cd3c said:9fingers":2pe6cd3c said:devonwoody":2pe6cd3c said:Thanks Jim, it will be an excuse to make a box. :wink:
Bob
Yeah, otherwise it will turn to ash.
9fingers":2oyc8mkz said:devonwoody":2oyc8mkz said:9fingers":2oyc8mkz said:devonwoody":2oyc8mkz said:Thanks Jim, it will be an excuse to make a box. :wink:
Bob
If you are careful it should be oak -a
Bob
devonwoody":31mtnl43 said:Thanks Jim
where is the green earth wire?
John,devonwoody":1kcqgvb5 said:Can I run to a 4 way socket extension from the nvr switch and then have the router and dust extractor running at the same time bearing in mind these switch ratings. (1400 watts dust ext. 2400 watts router, wait a minute! I am already running that lot through a 13 amp fuse plus the Jet mounted air filter)
devonwoody":1zb3k59j said:Yep, supply to my workshop is using 10mm cable from main consumer box , and then feeds a ring main from a rsd.
