Do you think it's still good, even though the sides seem to have some brown-ish residue? It's still sealed, never opened, however by shaking it I can tell it's still very runny. What is the forum's consensus on this?
Thanks!
I know the official shelf life is 2 years, but I have read titebond official blog (link) and found this:I would be very wary of using it.
This may help …
https://www.titebond.com/App_Static/Literature/ff876_ShelfLife.pdf
For example, store a bottle of white or yellow wood glue (polyvinyl acetate, or PVA glue) in optimum conditions, and it can last 10 years or longer. This goes for our popular Titebond® Original, Titebond II and Titebond III PVA glues, too.
However, I would like to know what is the general experience of woodworkers hereHow will you know if your glue has gone bad? “If it pours, it’s probably good,” says Behnke. If the glue has thickened, shake it vigorously by firmly tapping the bottle on a hard surface until the product is restored to its original form. You also can add up to five percent water to water-based glues (such as PVA glues) to thin the product.
In my experience (a few weeks ago) there's little if any difference between a new bottle and your example. But if in doubt do as suggested and test it after a good shake n stir.I know the official shelf life is 2 years, but I have read titebond official blog (link) and found this:
thansk Bingy, @johnnyb and @Noel - I'll do a test now and give it at least 18h before trying to tear it apartTry a little on a couple of off cuts clamp it up overnight and see how easy or difficult it is for you to separate. Does it simply break away clean or does tear wood fibres from the opposing pieces . Then decide - lot of glue to pour away ..
yeah, to be fair if it delaminates it's a big deal, but I think I'll just risk it - it's something for a personal project, so if it does delaminate in a couple of years I should be able to fix the damage (I hope!).Based on your pictures I’d certainly use it , however the only issue for me is time . By that I mean would the adhesive break down over time . Given how much force you have applied to separate the 2 pieces though it’s not something I’d throw away but I think I’d not let it hang around too long ( imo ) of course
Yes, it should be fine and I don't think it will delaminate or break down.yeah, to be fair if it delaminates it's a big deal, but I think I'll just risk it - it's something for a personal project, so if it does delaminate in a couple of years I should be able to fix the damage (I hope!).
How often and after how long bad glue delaminates, usually?
