AlwaysLearning
I'm looking for a hinge for a problem kitchen wall cupboard. The problem is the previous owners fitted the cupboard flush into a corner then tiled the wall.
So, 500mm wide cupboard carcass with a 496mm wide door, 18mm thick. It looks like the existing hinges have been cranked as far over as possible, but when it swings open, it catches on the tiles at say 60 deg of opening. The tiles stop 20mm short of the cabinet to the door sits in the recess. The tiles are 8mm thick.
I had thought about packing out the hinge from the carcass by 6mm, but then it would catch on a shelf and obviously form a 6mm lip at the edge of the cupboard. Trimming down the door is not an option since it's one of those vinyl wrapped ones. Other option is to pack the hinge and have a matching door made (if possible)
But, before I go down that route, I thought I'd ask if anyone knows of hinge I could simply swap out that would allow the door to be opened fully by offsetting it by 10mm say.
