Odate Crowning plate
Chris Knight
14 Jan 2004
SE London - NW Kent
I got one of these things the other day, having read David Charlesworth's comment on them.
It is a wide plate at 3 1/4 inches and not that long at 7 1/4 inches. However, in use I found that on my new plate four or five strokes was all that was needed to create a camber on a couple of A2 blades (previously sharpened straight across). The red, 600 grit stone I bought cut very quickly and left a nice even, fine, scratch pattern on the 35 degree secondary bevels I was using. I then went straight to an 8000 grit waterstone to remove the burr and polish the edge. (It's the only waterstone I use these days). On the waterstone I used the finger pressure method to maintain the camber that came off the Odate plate.
I got a nice sharp edge and tried the blade in a No.5 LN common pitch) on maple. I found that the camber was just right for jointing the edge of a board but too much camber (too small a radius) for smoothing - it wouldn't give me anything like a full width shaving at the thickness I wanted. This was not really a surprise as the leaflet enclosed with the stone made this very point. However, I was bit surprised as eye-balling the blade, it hadn't seemed particularly cambered to me. I checked the stone with a straight edge and feeler gauge which confirmed that it was dished to 2.5 thou as advertised.
I reduced the camber on a flat stone - again with a very few strokes - to something that gave me a good full width shaving.
There's no doubt this is a nice tool, easy to use and will be a great (albeit expensive) help to anyone who has difficulty creating a consistent camber. It's probably of most use when setting up a jointer or when establishing a fresh camber on a blade which is destined for the full sharpening process.
Thanks for the review, Chris.
I recently found I was getting too much camber on my blades. I removed the cambered roller from my MK II guide but still the problem persisted. Source of the problem was finally traced to my coarse diamond stone being cambered across its width - kind of an Odate for free :lol:
Needless to say, I have put the stone to one side :roll:
Philly :D
Philly :D
If you can measure the camber, you might be able to exploit it, sometimes.
BugBear
Phill - I'd suggest that if you were using the coarse DMT (blue) to camber the blades you may have been getting too much of a camber anyway. I use the extra fine (green) DMT and use the finger pressure technique (two or three strokes each side) on a MrC modified Eclipse honing guide which just gives the merest hint of a camber, which is all that's needed after all, the micro-bevel is then polished onto this camber on the Spyderco 10000g - Rob
What I did not say in the post, but in the article, was;
That I use the plate on the blade of a Holtey 98 plane.
This is pitched at 22.5 degrees, bevel up, so I do get nice wide shavings, much wider than in a conventional 45 deg pitch benchplane.
Glad you are liking it,
best wishes,
David
Aaah, now you tell me! :lol:
Oh well, I don't have a Holtey but I do have a few bevel up planes so I'll get my money's worth using it for them no doubt.
