Bodgers
So I bought another plane (it is becoming a disease I think). It is a Record plough plane.
Looks to be in usable condition, most of the cutters have not been out of the packet since the seventies when it was new by the look of them.
I sharpened up a couple of bits and got ready to do some test cuts in pine. A frustrating 15 minutes followed where I eventually figured out that I wasn't making any progress due to a secondary depth stop type thing being only used for the beading bits. Once that was ditched, I was on my way.
I now switched to the real job at hand - some beech strips I have that I am using as a sort of cap for a tool wall/panel. Basically cutting a 9mm square rebate down each length.
Some observations...
- I badly need a workbench. A B&D workmate and a plough plane don't play well together. I found it very difficult stabilising the whole setup with the direction and force needed on this plane.
- The shaving build up is very annoying in this plane. It is basically clogged after 3-4 strokes. What makes this worse is there are so many ways to cut yourself on this plane whilst removing shavings. There are two different leading edge scoring blades and the blade itself, not to mention other sharp edges. I had blood streaming down my hand from multiple different small cuts in this little session.
- I was planing strips about 1.3m long and 25mm thick. I had real trouble finding a clamping technique that didn't result in the fence bottoming out on the B&D workmate. Not sure how that would be any better clamped on a proper workbench...you need full open access down one side that you are making the cut on, and with a narrow strip it allows no room to run the plane down the length of the work piece.
- this is hard work. It took me around 30 mins to put a rebate in 9mm X 9mm down these lengths. Blade was sharp, (600 grit, 1200 grit diamond stone followed by leather strop), but there is a weird kind of sweet spot with this plane where it only seems to plane smoothly when it is taking a pretty thick shaving, any shallower and it seems not do anything. But the depth of cut means it can dig in occasionally - sort of like the natural inclination of a chisel. I found the method of starting at the end of the work piece and progressing backwards essential.
I did have a fantasy of tongue and grooving some wall panels with this, but I think at 30 mins per 1m or so I maybe having second thoughts
