Hi all
When I'm not woodworking I'm a bit of a music nut. I have a great set of speakers but I hate their metal stands so I'm gonna make some oak stands for them.
The stands will basically be a large lump of oak with the speaker sat on the top. Nothing fancy - just beautifull wood.
The stands will be 600mm high x 150mm wide x 200mm deep.
There is a guy down the road who has loads of offcuts of large French Oak beams so my first idea was to just thickness them down to the dimensions I want. The thing is the Oak will split - a look which I actually like but I think the vibrations of the split pieces of wood will affect the sound quality. I have a offcut of a beam and if you flick a split piece with your finger you can feel it vibrating.
So my second idea is to laminate 4 pieces of 150 x 40mm oak to get the dimensions I want. This should be less likely to split. I'm just not sure how successfull the laminating will be on pieces this thick- anyone ever done this.
The third idea is to get four pieces of oak ( 2 at 150 wide and 2 at 200 wide) and mitre them along the long grain. The hollow centre can be filled with sand to help dampen vibrations.
Would anyone like to offer some comments?
Cheer, Andrew
Cheer, Andrew
