Hello
Just hoping for some guidance. I’ve built a large oak door with mortise and tenon joints holding the stiles and the three ledges together. I now need to attach three large hook and band hinges. To do so I will need to drill through the stiles exactly where the mortise and tenon joints are located so that I can insert the bolt for each of the hinges. Do you think I am okay drilling through the joint (the hole for the bolt will be smaller than the joint and I guess it will hold it all together when the bolt is tightened). Just seems a bit odd having carefully made the joints I now need to drill through them all on the hinge side of the door. Am I worrying needlessly or have I screwed up? Thanks for any thoughts.
