JonnyD
I have had a short break from the kitchen project to make these. They are made from 64mm thick engineered oak and are double glazed with 24mm K glass units.
Size is about 2350mm X 1300mm
The lock is a wink haus cobra multipoint which I have used quite a few times now. The right hand door is the slave and bolts are shot up into the head and cill
The master door has a latch dead lock and 2 hooks which hook into the slave door. The system is really good with adjustment on cams to all the locking points which allow easy adjustment on site and its easy to adjust for seasonal movement if required.
The doors fold right back against the outside walls and this is what they look like internally.
The doors and locks were all fitted in the workshop and it makes fitting on site loads easier you just need to make sure that the frame goes in square and you check the fit of the doors before fastening the frame back.
Thanks for looking
Jon
Thanks for looking
Jon
