head clansman
hi mike
BSM pretty much covered it in his description here
Mike.C wrote:
BSM wrote
keep the length of pipe work from extractor to the blast chamber as short as possible and the blast chamber itself as small as possible . that also applies to the pipe run to the machines as well. Thats the reason i split my shop in half length ways machines one side, work area the other side shorter runs of pipe more suck . hc
Mike wrote
It does work , the best of both worlds switch form one size pipe to the other with a push/pull of two gates,which has then then opened either the 50mm blast gate to the hoover, or shut off the 50mm side and open the 100mm blast gate to which ever machine your going to use .
I only use the 50mm pipes for hoovering with a 7 meter hose attached all other is 100mm pipe to all machines and to a floor pan for shavings and other crap , never use the 50mm for this as it will block 50mm hoover is use only for light dust . hc
Mike.C wrote:
Martin don't let anyone hear because I will feel a right idiot but what is a blast chamber
BSM wrote
it is {i think} a box or chamber from which you run mutiple pipes - each one shut off with a blast gate
so rather than having one long pipe from the DE with T joints and blast gates at each machine - you have a short pipe run to the blast chamber then radial pipes from there to the various machines.
the benefit being that as only one machine is in use at a time, at any given time you have the minimum ammount of piping open and thus preserve your suck as far as possible
Mike wrote
Spilting the system could work. I will have to give it some thought.
