This is my first attempt at making any kind of knife my father does hawking and needed a good knife so I thought I'd have a go from scratch,
I know it's alot of metal but the handle's wood...:wink:
I started out with a bar of 01 steel 30mm x 4mm
Roughly cut out with a hacksaw
Little work on the grinder
Gave me this
Now time to bevel the blade edge I made this jig from a link I found on the net, all done with varying size files...
Gave me this!
Next to diamond polishing stones used wet
I missed a bit here as I got a bit excited as the next step which was forging the blade, this I did by hollowing out the centre of a large air/fire brick then drilled a hole in the side to let a propane torch in, I heated the blade until the metal became un-magnetic the quenched it quickly in a 2 gallon of cooking oil then reheated it with the torch to hopefully temper it and ended up with this...
A bit more polishing!
Now for the handle I used Amboyna burr
Cut roughly to shape
Drilled out
Pins used for attaching, these are hollow rod as I added buffalo horn as an insert!
Roughed up the tang and handle
Joined together with epoxy
Clamped up
After 24hrs I sanded it all around to follow the tang...
Now for shaping the handle again with varying size files
And sandpaper right up to 2000 grit
now it's steeped in a solution of 50% linseed oil 30% turps and 20% Danish oil for 36hrs
Dried for a week a lightly buffed I'm not 100% happy with the finish so I may try something different soon...
Sharpened it to 20 degrees and it easily take hairs off my arms...
Hope you like I'm really happy with for a first go... Please let me know what you think!
Gave me this
Gave me this!
Drilled out
Clamped up
