bugbear
D_W":2g6b5ei4 said:I can't imagine sharpening kitchen knives on synthetic waterstones...
Pretty easy. Even I can do it. Lots of videos on line showing how.
BugBear
bugbear":21egb0jc said:memzey":21egb0jc said:Can ipa be used with shellac instead of meths?
Yes. Basically you want the purest alcohol you can get/afford. Beware of "rubbing alcohol"
which is 30% water, and won't work at all.
BugBear
bugbear":28ezkm0s said:D_W":28ezkm0s said:I can't imagine sharpening kitchen knives on synthetic waterstones...
BugBear
G S Haydon":1wxr0f15 said:The fine India is a fantastic stone and low cost. Very, very good value, I would imagine you'd struggle to wear one out within a lifetime. They bite pretty hard when new but settle down to a nice level after a short while. I use mineral oil on mine and sometimes switch to a little white spirit for a few honings if it feels like it has slowed down too much. The edge from an India is perfect for just about all woodworking tasks, add a bit of autosol to a block of wood and it get's the edge even better.
The only thing I've used on it that I didn't get good results was A2 steel.
I've still got my first one from about 1960 something. Have a few more now, should see me through several lifetimesG S Haydon":5em5ahah said:The fine India is a fantastic stone and low cost. Very, very good value, I would imagine you'd struggle to wear one out within a lifetime.
I freshen up the surface every now and then with a 3m diapad .They bite pretty hard when new but settle down to a nice level after a short while.........l.
Thanks. Without wanting to derail this thread is there any benefit to using pure ipa over methylated spirits for mixing up shellac? It costs a bit more and is not as widely available so if there is no benefit I'll stick to meths (not the druggie kind).bridger":kcndni1n said:bugbear":kcndni1n said:memzey":kcndni1n said:Can ipa be used with shellac instead of meths?
BugBear
Ah yes... two nations divided by a common language.
This side of the pond (usa) meth refers only to methamphetamine, a particularly nasty street drug. Rubbing alcohol refers to isopropyl alcohol, in any concentrarion. My local cheap source ( big lots) carries it in 50%, 70% and 90%. For cleaning I prefer the 90%. For honing I have come to prefer the 50% as it doesn't evaporate as quickly. However, I live in the Arizona desert- your mileage may vary.
Isopropyl alcohol is one of the additives to ethanol which makes it 'de-natured' i.e. undrinkable. Methanol being another - making it 'methylated'.memzey":1ljq1jm8 said:Thanks. Without wanting to derail this thread is there any benefit to using pure ipa over methylated spirits for mixing up shellac? It costs a bit more and is not as widely available so if there is no benefit I'll stick to meths (not the druggie kind).bridger":1ljq1jm8 said:bugbear":1ljq1jm8 said:.......
BugBear
