raffo
yes. 3, 4, 4.5, 5, 5.5, 6, 7, 8.
And 5.25
I think you'll find that was a No.7. ......
I like every apprentice started out with the obligatory No4, then a No4 1/2 as a lot of the joiners had them due to their increased weight. I then purchased a No5 1/2 but it was too heavy to carry with all the other tools.4 is cheaper!
The point about 5 and below is that they light enough to use against a vertical edge like a door, or around a table edge, or smaller ones one handed.
5 1/2 or above are getting too hefty and only for horizontal use, unless you are into weight lifting
A man after my own heart. I agree that for installation work a block plane and a #5 was the way to go until we got affordable power planers. It was all about weight, bulk and utility - still is, reallyI like every apprentice started out with the obligatory No4, then a No4 1/2 as a lot of the joiners had them due to their increased weight. I then purchased a No5 1/2 but it was too heavy to carry with all the other tools.
After a few years and knew what I was doing I progressed to a block plane and No5 which I found more useful when hanging doors.
I would definitely second that!You cannot really flatten or straighten anything with a smoother (for instance number4) without wasting lots and lots of time on it. For all flattening and straightening operations you needd longer planes to achive a tolerable level of work efficiency.
Depending on the sort of work and the lenght of the workpiece different lenghts of planes are suitable for flattening/straightening. In part it is also down to personal preferences.
The basic set of longer planes for such work would for most of us be a number 5 and a number 7.
