A
Anonymous
Guest
I just got one of your books from the library Mr Charlesworth, and theres some good stuff in it.
I think the krenov type doweling jig is bloody superb, I will use that next time I laminate up a chair seat as it will save a lot of time. I generally use a marking guage to scribe a line off of the face side's on either plank, then square across both planks together for the peg position's. Then use a brace and bit. But with this you can mark out with the jig and use it for drilling in the same process, less acumulated error. Nice one, just 2 nails as a temp fix. Should work a treat with a bahco type bit where theres a loy of surface area on the outside of the bit. (I'd be going into side grain on both board's) It could even be modified to do holes at compound angles eg a row of spindle socket's in a plank chair seat to do a matching set of identical chairs.
PS a nice book, David. Can I ask how you did the roof of your workshops? was there any tie beam's in there originally? and how did you make the new roof? (nosy arent I :lol: )
Cheers Jonathan
Cheers Jonathan
