Newt's Plane
If Carlsberg made planes, they'd probably look like Pete's :D
Pete's plane is stunning, both to look at and to use. In particular, the brass lever cap, brass screws and the blade and cap iron are works of art. I feel quite privileged to have had the opportunity to try it out - thanks Pete :D
Cheers :wink:
Paul
My question answered then. No knobbly gouge marks like Krenov's planes....
Lovely job.
Would maple be suitable for such a plane I wonder?
I would be scratching to make the brass cap though!
Again, nice going
Hi, Pete
Nice plane mate and mega shiny brass. Any difference between cap iron and just blade? I am undecided my self about cap iron on thick blades my small block plane works fine but it does have a 6mm thick iron.
Pete M I think I said earlier that I did design it so I could use it with or without the Cap Iron ( C I). With the C I it seems to require less effort which surprised me I thought it would be the other way around. However the big difference is that the shavings come out in tight curls with the C I but fairly straight shavings with no CI. Moving the CI back to about 1.5 mm from the cutting edge makes the curls much looser about half a mill seems to be the optimum. The curved edge of the CI is highly polished, I perhaps should have tried it when it was dull to see if it made any real difference.
Pete made this one from beech, a traditional plane making timber but as we discussed this afternoon, any timber within reason could be used 'cos a separate sole or shoe is one of the things incorporated here. This means that if you had a nice lump of English Walnut that was going spare the main body of the plane could be made from that and then a separate sole of something much harder (say lignum, rosewood or hornbeam) could be glued to the underside.
If a separate sole is used it's absolutely essential that a 1:1 drawing is done to work out exactly where the pivot points go on the cap and where to drill the holes in the plane side for them, otherwise it's a bit of a guesstimate as to where you put the holes as I found out when I made a similar plane a while back in Cuban Mahogany and Rosewood :( .
Also, it's much easier to fit the mouth if a separate insert is made into the sole and fixed with a couple of brass screws.
The brasswork is more difficult to make than a wedge but I think, like Pete, that the blade adjustment becomes easier as the screw can be slackened off a half turn so the cutter is just held and then adjusted with a Philly style tapometer....a half a turn again locks the whole thing solid just above the cutting edge where the cap touches and also at the top where the screw bears....worth having a go - Rob
newt":1hitfbbp said:
You may like to know that the plane weighs in at just under 2 pounds.
Pete, I thought the weight of the plane felt really good in use. As Rob said, the brass lever cap probably gives it some more heft, and I always think a heavier plane performs better than a light one.
Cheers :wink:
Paul
