Newbie balls up?
Mike, thank you, perhaps what I may do is bandsaw it in half for a box or similar.
Adam, also, thank you for your well meant advice, no apology necessary. And sincere thanks to all who have posted with their ideas, it is much appreciated.
My biggest problem is that I have several large sections, probably just under a tonne, which I have not been able to plank due to their short size, and being a beginner with this type of work, am reluctant to ruin through ignorance. We had to cut down this beech tree due to its proximity to our septic tank, and my father (now deceased) planted it about 35 years ago. My bandsaw only has about a 6" jaw (sorry, depth of cut) and parts of the trunk sections are about 2 ft across. So as long as I can make a few things out of it i.e. a box or two, maybe some small bowls, cutting boards (not sure now), I shall be happy.
Thanks to all who kindly answered.
Howard
It looks like a super piece of wood. Could you change your plan and re-work it into some sort of decorative piece, so that the hygiene aspect would not be an issue. Perhaps a backing plaque for a trophy or medal? Or go really crass and scroll saw it into a key shape, then screw in some hooks to make a key holder. Seriously though, it could be the basis of something stunning.
K
I am a little far north of yourself, but perhaps there might be someone here close by who may be able to help you out with the best way of utilising the timber, as it often needs to be seen in the flesh to get a good feel for its' potential. If you are new to this, then perhaps the thing to do would be to find somewhere dry to keep it (if possible) until you are more confident/proficient. You mention bowls - if you have a lathe then that might be the best option for now, but you would need some way of reducing the timber size, I imagine. What are the rough dimensions of pieces that you have?
Adam
Kalimna":3mm1e0o7 said:
..... to have it in frequent contact with moist food (eg cheese) might not be the best course....
No it'll be OK. Cheese is itself crawling with microbes anyway.
Yes bowls could be good. Bowl carving is an alternative to turning and is appropriate to low grade "found" wood which could be unsuitable for finer woodwork.
Thanks Gents, very helpful. Adam you are absolutely right, I'll take a photo tomorrow and try to offer some scale. The largest trunk section is about 2ft across but only 6" thick, but there are other sections which are smaller in diameter, approx 16" but much thicker up to about 16-18" - rough guess. I have petrol chainsaws, big enough to rip down the middle. I also have a lot of shorter bits about 6-8" dia. which I have logged to about 18" length, but I suppose they could be turned - yes?
Kryten":2q300ldg said:
......I also have a lot of shorter bits about 6-8" dia. which I have logged to about 18" length, but I suppose they could be turned - yes?
Ideal for bowl carving - this sort of thing:
A lot of misinformation going on here. How can spalted beech be 'unhygeinic'? And if dry then the fungus is no longer active or at least is in suspended animation - no 'spores' are going to appear ... If there's a defect, it's that the paler areas may be rather soft - are they (thumbnail test)?
Jacob.
Listeria Monocytogenes is a 'microbe' that can be found on cheese. According to you it must be ok. Well, it is for the 4 out of 5 people who get a listeriosis infection from it. The 1 out of 5? Well, they wont be eating cheese, or anything else for that matter, ever again.
Mycobacterium Tuberculosis. The name should give away the disease it can cause.
Salmonella.
Yersinia.
They are a few of the several 'microbes' that can be found 'crawling all over' cheese. Please research their respective infectious capabilities.
Kryten - I shall leave the turners amongst the forum to offer advice on how best to utilise your timber for tunring :)
Cheers,
Adam
P.S. Jacob - nice bowl idea for those without a lathe.
P.P.S longinthetooth - spores are fungi in suspended animation. That is the whole point. Anthrax spores are the same thing, and you wouldnt want to consume them.
Kalimna":39yz47az said:
Jacob.
Salmonella.
Yersinia.
So cheese is off too? Where will this end? :roll:
for those sizes of timber perhaps a better alternative to turning even if you have lathe.
I think there is some scare mongering going on here. The advantage of many hard woods, if not all, is that they contain natural chemicals which kill pathogens. That is why a felled tree takes years if not decades to rot away, even when exposed to the elements. The reason is simply that the tree produces these chemicals as a self defence, since they have to last hundreds of years. And spalted wood is caused when fungi grows into the wood. What you see is the result of the fungus digesting components in the wood. The part of the fungus in the wood is the mycelium, which contains no spores. The spores are produced by fruiting bodies externally. So the spalted wood is quite safe. But use normal hygiene practices of course i.e. wipe clean, and treat with a non toxic oil. I think tung oil is non toxic, and it cures to a hard layer. Apply many coats and you get a good protection. and when it wears you could always refinish it.
That wood is wonderful. It deserves to be used for display purposes. Spalted wood (maple?) is sometimes used for guitar bodies, in veneer form of course. I think it is too beautiful to be used for a day to day object. Could you not make something to place on the mantlepiece, or in a glass fronted cabinet?
By the way, if you want scaremongering, not long ago a chap died from aspergillosis caught from spores inhaled when he handled compost.
Thank you Leif, extremely informative. I'm sure I can find some use for it for display purposes. I used Walnut oil originally, so whether Tung oil (if I can find some) will soak in I do not know. But I prefer your suggestion of using it for display. Any ideas for that most welcome.
Thanks again.
Kalimna":39x18vb4 said:
Jacob, and I really shouldnt rise to this, but more people would take you, your experience, and your sometimes very good advice seriously if you weren't such a pillock on occasion. ......
Cheers,
Adam
That's why I put him on Ignore.
Your advice is very sound, Adam.
Re. problems with spalted beech, I would go with Leif on this one in that spores only come from fruiting bodies. The pro-spores school here could argue that it is not known if fruiting bodies have existed and therefore there could be spores around - accepted, but the concentration will be very low now.
One thing that few people know is that if something is dried below 18%RH any mould (fungus) or bacteria cell will die due to all the moisture being sucked out of the cell. I first learnt this from keeping bees who 'dry' honey to this level before sealing the cells, and then met up with someone in the grain storage business who said the same RH level applies there too.
Any wood to be turned dry should be well below 18%. Fresh 'wet' wood will be as high as 30% - typically it will be 60% when growing and will lose half of that as free water when the tree is felled. Turning wet, even damp, beech where spalting is present is not advisable as the fungus cells will still be active and have been recorded as causing lung problems.
The discussions above are both correct in my opinion but for the wrong reasons.
Rob
OldWood":3ugakg76 said:
Any wood to be turned dry should be well below 18%. Fresh 'wet' wood will be as high as 30% - typically it will be 60% when growing and will lose half of that as free water when the tree is felled. Turning wet, even damp, beech where spalting is present is not advisable as the fungus cells will still be active and have been recorded as causing lung problems....
Have you any evidence of this?
Why should wood be turned below 18%? Yes wood needs to be below 20% ish to prevent rot but this doesn't mean it can't be turned. In fact the sooner the better as it will dry quicker with less risk of splitting.
Turning wet wood is widespread, for a number of good reasons. Fungus infection is common. If there really was a problem I think it would be well documented by now, but all we have is a few rumours.
Looks nice. I probably wouldn't worry too much, you arn't using it for raw meats and you can wash it with something like vinegar every now and then. I'm not sure but perhaps its a little thin for the grain direction, if it dropped perhaps it would break along the grain lines, just a thought i'm not really sure.
Guys
I really appreciate all your advice and taking the time to offer your help. It does look as though after Googling that it is 'fairly' safe to use for say, cheese for example. But maybe as suggested earlier in the thread, I should do something more decorative with it. I've acquired a bandsaw since I first posted, and as this beech is between 17mm - 19mm thick so maybe I might saw it down the middle and make a small box or something. I just need to practice on my corner joints or dovetails first.
Do post photos of the finished article.
RogerS":2rem3yil said:
Googling spalted turning fungus lung problem produces some good results
I could not find anything substantiated, although I did not search for long.
To those who worry, the air is laden with spores, especially in the autumn. A single fruiting body can produce billions of spores, and I think some people are allergic to fungal spores, as I am allergic to pollen in June which I think comes from crops. So a few spores is nothing to worry about. Bacterial spores are another issues, and you don't want anthrax spores in your lungs.
The earlier poster is correct that fungi cannot grow on dry wood, although dry rot will breakdown dry wood once it has become established. It needs damp wood to gain hold, and then apparently can live off wood at 20% moisture content. The reason why fungi are in general not a threat to us is because our body temperature is (only just) too high for fungi to grow. It has been suggested that the reason why our body temperature is so elevated is to avoid fungal infection. So even if you do inhale fungal spores - and you do so every day - you will not see mushrooms growing on your body, or in your lungs.
I think you need to worry more about inhaling wood dust, and the chemical vapours in some varnishes and other finishes.
Oh for chist sake, why don't we all just jump into our graves early and be done with it!!!! The Op asked a simple question, he didnt ask for scarmongary or Darwins Theory. I agree with some of the other post, that lovely wood should be displayed and not used as a cheese or chopping board, regardless of how safe or unsafe it may be. I am no microbiologist or scientist and do not have a clue about a what fungi spore will do to you, and quite frankly I don't care. I am actually interested in what the op has in mind for that wood and the suggestions for it from the other forum members. If that upsets people then so be it, get over it and get back to the point!
I do hope you find a suitable project for the wood and share some pictures with us all.
