llangatwgnedd
or is the freesat signal poorer to start with Think
Sky, Freesat and FTA use the same transponders, just the EPG is different, thats all.
PaulR":13r5xlgd said:i went into comet the other day, they had a display of plasma, lcd and led tv's above each other, there was quite a difference in the picture quality so worth you doing the same comparison to see what you like
paulm":pb8l9a0n said:I picked up the last cable in Maplins Roger, this one I think http://www.maplin.co.uk/Module.aspx?ModuleNo=227277 but don't know how to identify if it is any good or not ? Just go on price or a different supplier ?
On a different topic, how do you format links like that to show as a coloured word rather than a long url ? I think you need to add Paul
You need the following syntax [url=your.www.here]your highlighted word/s here
Like this
TrimTheKing":106zcc8n said:paulm":106zcc8n said:I picked up the last cable in Maplins Roger, this one I think http://www.maplin.co.uk/Module.aspx?ModuleNo=227277 but don't know how to identify if it is any good or not ? Just go on price or a different supplier ?
Like this
http://www.wonderhowto.com/how-to/video/how-to-paint-distant-trees-in-watercolor-90511/view/here
yo_chuci":10mq1uwb said:hi... just catching up...
the tv you like is available here for £865.
bought my dads on thru them. with tosh dvd upscaler and otehr bits and save a few hundred quid (inc a 5yr warranty)
satellite aerial cable the best stuff to go for is air filed (but that can let water to your equip if it ever gets damaged outside. most use foam filled for that reason...) how much do you need i might have enough on the end of a reel pm me.
devonwoody You need the following syntax [url=your.www.here said:
paulm":u7lutlo1 said:devonwoody You need the following syntax [url=your.www.here said:
