scrimper
finneyb":2u6lxnn7 said:martinka":2u6lxnn7 said:finneyb":2u6lxnn7 said:Does the Hegner quick release clamp fit? I don't know but would expect it would. Alternatively you can make your own using 4mm threaded bar with a couple of nuts and lever turn it - I use a small mole grip as the lever and it works fine.
Brian
Yes it does fit, but it's not as simple as that to make your own. The Hegner quick clamp has a rotating piece at the inner end of the 4mm thread which stops the tendency of the blade to twist as you tighten it.
Martin,
I accept that Hegner Quick clamp has rotating piece as you say and I can see what they are saying about the blade's potential to twist. I've never noticed problems with the blade twisting using my method above. Mike's workshop has a lever that's been mentioned on here before and so far as I can see there is no rotating piece on that either ie its just like the method I use. Mike does make it clear that his lever is not a Hegner product.
Brian
My Hegner quick clamp does not have the rotating piece in it but I have never found it's absence cause any problems. I bought my Hegner in 1999 so it may be an earlier design quick clamp.
