MIGNAL":zctwwx2t said:I too used Bubinga when I restored my stanley No.4. Cheaper than Rosewood and just as good. Mine was blander looking than your stripey stuff.
I honestly can't remember how I drilled the hole. I only had a cordless drill at the time so I think used an oversized piece of wood and referenced everything from the resulting hole. . . . I guess.
I have probably (not recently, but in the past) made a dozen handles for planes before getting interested in building entire planes - made them out of indian rosewood, cocobolo and macassar ebony (whatever was inexpensive in the shorts bin at the local plastic/MDF/Aluminum junk and dust collector woodworking chain). A friend and I tried drilling with a long reach bit and a drill press setup, but always had wander problems. I found it a lot easier just to use a cordless drill and drill from both sides of the handle, meeting in the middle, with a marked line on the handle as a visual cue.
Always shaped them with a rasp, file and then sandpaper, and never had one that needed to be thrown away from that. The templates are nice, but often don't create a handle that is flush fitted all the way around with the base on a given plane.
