New Planes from Lee Valley
sparky":33slc8nb said:
i just checked out chris schwarz's blog and he tells of dinner that he had with Rob Lee :eek:ccasion5:
have a look :tool:
http://www.woodworking-magazine.com/blog/
the plow plane has me excited... because i want one! =P~
sparky
The small router is clever too. It uses a captive bolt being PULLED by the nut, which means all the tension forces (and threads) are in steel, with the cast iron feeling nothing but compression. Further, the blade can be removed by simply loosening the nut. The nut/bolt can then be reversed into the other position (bull nose). This is 99% as slick as the Preston #22 mechanism (inherited by the Record #722), and much simpler to manfacture.
http://www.geocities.com/plybench/record.html#722
BugBear (Kudos to Rob Lee and his design team)
