"New" P/T - what oil for the gearbox?
tigerturnings
29 Mar 2006
Hampshire
So, there's a new arrival in the workshop:
A Wilson P/T, will plane 21" width and thickness 20" by a little over 9".
There's a little oil reservoir on the rear of the machine which I think supplies the gearbox that drives the feed rollers. What kind of oil should I fill it with? I would guess that SAE80/90 oil as used on motorbike chains would do a fine job, but is there anything better I should choose instead?
TIA!
Neil,
That is a magic looking bit of kit, you cannot beat a large lump of cast iron for stability. :D
Sorry no idea what oil you should use but your suggestion sounds about right. :-k
I would err on the side of Hypoid Gear Oil SAE W80-90, will stand a bit more high pressure if there's a chance of bevel or worm gears.
Should find it at local motor factors, possibly labeled for use in differentials etc.
thats a nice compact planer :lol:
SAE W80-90, gear, diff oil sounds about right. just don't use second hand oil, all mucky horrible and thin.
