NEW JessEm Pocket Mill Pro
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
Made in Canada
No matter your skill level, the JessEm Pocket Mill Pro makes perfectly accurate mortises with only a hand drill. Built to last, this tool is the perfect addition to your workshop! You can cut a mortise on the end, face or side of a board, you can also tackle mitred edges with the optional Baltic Birch Milling Workstation.
Patented Process
The Pocket Mill Pro is made of anodised aluminium with hard-wearing stainless-steel components. It makes perfect holes using the patented step-down process.​
The Perfect Cut
With each lateral movement, the jig automatically drops 1.3mm and works its way through your material until you've completed the perfect cut.​
JessEm is proud to launch the Pocket Mill Pro Loose Tenon System
Loose Tenon System
£369.95​
Buy Now
with Baltic Birch Workstation
£539.95​
Buy Now
JessEm Endmill Kit
5mm
£54.95​
Buy Now
JessEm Endmill Kit
8mm
£89.95​
Buy Now
JessEm Endmill Kit
10mm
£99.95​
Buy Now
