- Joined
- 16 Nov 2021
- Messages
- 188
- Reaction score
- 58
Made in Canada
No matter your skill level, the JessEm Pocket Mill Pro makes perfectly accurate mortises with only a hand drill. Built to last, this tool is the perfect addition to your workshop! You can cut a mortise on the end, face or side of a board, you can also tackle mitred edges with the optional Baltic Birch Milling Workstation.
Patented Process The Pocket Mill Pro is made of anodised aluminium with hard-wearing stainless-steel components. It makes perfect holes using the patented step-down process. | The Perfect Cut With each lateral movement, the jig automatically drops 1.3mm and works its way through your material until you've completed the perfect cut. |
JessEm is proud to launch the Pocket Mill Pro Loose Tenon System
