Blackadder
Hi all.
I have lots of Sash windows installed about 10 years ago - hardwood frames / sashes with double glazed 4/16/4 units in a 30mm rebate with a 6 x 16mm external bead. Seems like the design was badly flawed because the sealing between the bead and the glass has failed on most windows, allowing water to sit on the bottom rail causing algae and mold to grow on the glass and soak around the glass onto the inner of the rail and also distort it. What is especially interesting is that there are no spacers between the rail and the glass unit - it sits tight in the rebate on all edges.
So 1st question - is the lack of a 5mm spacer at the bottom (and gaps at the sides / tops) the root cause of the sealing failing? If so, I'll need new units (~5mm smaller each edge) and may well have problems with it affecting the sight line (cost and complications). If not then maybe it's a case of cleaning and drying it all up and rebuilding and resealing. Any suggestions on how to seal? What I suspect makes this tricky is that the bead is so small (only 6mm wide) and the front of the house is VERY exposed south facing - so lots of baking sun and rain like its from a fire hose (although same issue - just not as bad - on other elevations.
Any advice appreciated.
D
D
