Pekka Huhta
Oh boy.
I made a lathe. To turn me chisel handles. I had half a forest of "visakoivu", curly birch, masur birch, gnarly birch, whatever you call it. Curly, nice wood which is regarded over here in Finland as the best possible stock for any chisel handles, as it just can't split.
Makes you think it should make nice chisel handles.
They were.
A good 2" framing chisel for my timber work. I was proud as (***) for that one. The hitting ring by the way is a half of a 3/4" water pipe connector. It seemed to me as a nice touch, probably it is.
But the bench set. Bummer. Did not get thrugh on my quality control.
Although "visakoivu" is so resistent of splitting that I have old chisel handles which have been hammered to stumps without splitting, it just won't translate to socket chisels. They just don't take the bend on the socket.
At least the last set got right, at least this far. Set of small butts with Eskilstuna steel on the other end.
Well now, I shouldn't be depressed on this one. Still, I am :roll:
Not a bad one. But still it took me weeks to get the time to turn them all with that pretty but flimsy lathe. Not to speak about building the darn lathe.
The last touch for the day was that I got the last chisel blank flying to my forehead from the lathe. A helluva bruise it gave me. And as I got the blank finished it broke off on the first good try.
Whiney whiney whiney.
I guess we all have these moments from time to time, but this just got me a bit too bad and I thought to share a few bad moments instead of the endless successes we always see on the forum
Pekka
P.S: Could someone just put me out of my misery with a good set of just regular, old, carbon steel bevel edge chisels with proper boxwood handles. Really. A PM will do
They were.
Pekka
