kevinlightfoot
It is time we had a new boiler,the boiler at present is working but we had troubles last year.It is the type of boiler that you have to pressurise and if the pressure drops for any reason the boiler will not work.It runs nineteen radiators and gives us domestic hot water,some radiators get hot some don't,my old house was also quite large and the heating engineer put in a double Grundfoss pump(two pumps side by side) I think I may need this.I want to have a boiler fitted with a proper header tank installed and a proper thermostat where you don't have to keep moving it to different parts of the house and the whole house keeps warm.My question is what are the chances of a heating engineer being able to do this and the system being efficient and reliable and by efficient I do not mean fitting money saving gadgets that do not work.All I want is to be able to switch the heating on using a timed device and the house,the whole house to get warm.Any comments or advice would be gratefully received,regards Kevin.
