At least 15 years ago I picked up a record 77a bullnose plane on eBay thinking that I needed one.
It arrived and I sharpened it up as usual but found it was pretty useless compared to a block plane or a sharp chisel. I couldn’t get it cutting properly and so it went in a drawer.
Now I’m in the process of finishing off my workshop I was unpacking everything and came across it again. It’s a nice little thing and so I thought I’d give it another go.
The bevel showed my sharpening 15years ago wasn’t as good as it is now, so I carefully reground it, honed a fresh bevel and gave it another try on a bit of pine from the offcut bin.
It was still dire, refusing to take a nice shaving. Taking the blade out to have a look, the fresh bevel had completely crumpled, as though I’d just tried planing 60 grit sandpaper.
Intrigued I found I could easily deform the bevel with my fingernail, showing the blade was nowhere near hard enough.
Rather than just putting it back in the drawer, or selling on eBay to disappoint someone else, I thought I’d make up a new iron and see if I could get the plane to be able to, well, plane.
i ordered a piece of O1 in roughly the right size, a bit over on width and 3mm thick as supplier didn’t have it in 2.5mm, and thought thicker was better than thinner
After tracing round the outline I set to with a hacksaw to cut to shape, slowly raising in the vice to control
A tidy up with a file and I had the rough shape
gave myself a bit more length after first checking it would fit with the depth a
Then was the fiddly bit, making a nice neat slot. Not having a mill I drilled a hole at each end and then after finding my needle files woefully inadequate I chanced a Pegas wood cutting blade in a fretsaw. Luckily it worked and meant I could saw out the waste big enough to get one of my better files in for tweaking. Need to order myself some proper metal cutting blades, but was impressed by the wood blades
Next was heat treat prep, which involved making sure all the internal corners were rounded to protect against stress risers and cracks. Then a coat of anti scale compound, to protect against decarb, and also try and avoid having to do too much clean up work to polish the back. Without a surface grinder lapping away pitting from scale is no fun.
next was heat treating
