NEW AUKTools Professional Router Fence
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
One of the most advanced in its price range
Featuring a dual-track fastening system with adjustable scales that can be set for zero reference allowing for fast, repeatable setup. A scale is also provided along the top of the fence with the zero position at the centre in both metric and imperial measurements. On the front face of the fence, there is a second T-Track to accept either the included Clear Bit Guard or optional extras such as JessEm Clear-Cut Stock Guides or Feather Boards.​
ONLY £219.95
Smooth Action
The fence glides smoothly in the tracks and locks firmly with the twist of its ‘high-boy’ lock-down knobs.
High Quality
It is constructed of a single extruded aluminium section with a red anodized finish.
Tool Free
The HDF sacrificial sub-fence faces are edge banded to ensure smooth gliding of your workpiece and can be adjusted tool-free with convenient locking knobs.
Convenient Storage
The shimming bars are designed to offset the fence face by 0.8mm (1/32") or 1.6mm (1/16"). When not in use they conveniently store on the backside of the fence.​
AUKTools Essentials Router Table Package
The AUKTools Essentials Router Table Package combines everything you need to get started with a professional standard router table setup. Designed to be budget-friendly but still with high-quality materials this router table will elevate your projects to the next level.
Package Includes
AUKTools 800 x 600mm Router Table Top
AUKTools Router Table Stand
JessEm Rout-R-Lift II (Imperial)
AUKTools 1500W Fixed Base Router
AUKTools NVR Backing Plate
£999.95
Normally £1,134.72 when bought separately​
