clamped to a shelf, just like in schoolI've only learned how to use a pencil parer in the last few years.
Now I can use cheap pencils and not have the tips break off.
Maybe it was just me twisting them pencils wit me wonky fingies...
Doesn't seem to work the same for carpenters ones unfortunately..maybe needs a sharpen, kinda different design of those so couldn't compare my test.
How do you hold your sharpener?
Yes I find mechanical pencils to be the most useful, a lot people appear to overlook them for some reason.I like to use the type of pencil, don't know what they're called, but the type you load up with leads and click the end to extend the lead. You have a choice from H through to 3B and from 0.5mm to 0.8mm. They are always sharp, cheap, and most have a pocket clip so they don't roll around when you lay them down.
But not so compatible with glasses.I have a pair of very useful pencil storage facility - they're called ears - just tuck the pencil behind one or the other. Simples.
And/or hearing aids (and in my case)But not so compatible with glasses.
find that quantity wins over quality!
In my experience the 0.5mm and 0.7mm sizes popular for writing are too fragile and wear too quickly for workshop use. I moved to 0.9mm mechanical pencils and 2mm clutch pencils (which act like wooden pencils in use) a few years back and never looked back. And a couple of water soluble Chinagraphs for marking things other than wood.Yes I find mechanical pencils to be the most useful, a lot people appear to overlook them for some reason.
