Phil Pascoe
Semantics?
I'm surprised someone hasn't come along to enlighten us. :lol:
Mark Hancock":29wsd2on said:I did some research on this topic a while ago when a new range of negative rake scrapers appeared on the market and the conclusions I came to were:
1. the rake angle is the angle between the tool and the work
2. negative rake is an angle less than 90 degrees
3. a standard scraper (no top bevel) when presented in trailing mode presents a negative rake angle
4. negative rake scrapers (with a top bevel) are usually presented horizontal hence the need to have a top bevel
The whole issue of negative rake scrapers is somewhat confusing because IMHO of the use of terminology and techniques from metal turning being applied to woodturning.
I can see a use for negative rake scrapers in confined spaces such as the inside of a box but I just don't understand the need on a bowl when simply lifting the handle on a standard scraper gives exactly the same presentation angle to the work... maybe it's just me :roll:
phil.p":2jnm2zqw said:I was acutely aware of the proximity of the scraper handle to my jaw.
CHJ":2eqvyb11 said:What happens if a novice tries to use a negative rake scraper in bevel rubbing mode inside a piece?
Cutting edge would have to be on centre at best, more likely below centre so very prone to dig-in.
