Having been fired into some giving some more thought to this, my hope on using the Festool saw and guide in some sort of jig are now much diminished. Well l should say the ability to QUICKLY make several cuts on a large sheet with the accuracy and quality of cut that the Festool gives is diminished. Of course heaving the board onto some saw benches measuring and clamping the guide at both ends, (and then rechecking in case adjusting one end moves the other a knits tit), and then, depending on the cut, sliding the saw to the end, now somewhat at my maximum reach on tiptoes, will do the job very nicely, but just not very quickly.
So to think out a mechanism and procedure to quickly and accurately get the guide rail in place did not seem too much of a problem. However, having spent a few cold hours in the workshop today, I think it’s a non starter. The problem is the guide rails, good as they are for their purpose, I think they are entirely unsuited to being utilised in a jig as projected. They work so well because they sit on the panel being sawed. They have gripping ‘rubber’ so that they can be used without clamps, although I find it preferable to clamp up firm when using the system. The only way the guide rail can be moved easily is when it is clear of the surface, and for sawing the guide rail should be hard to the surface. Add the complications of wanting to saw differing thicknesses then the whole frame (or whatever) holding the guide rail will need to be lifted and lowered accurately. Its all getting too complicated for me. The only way I see of getting Quick and Accurate cuts from large panels without endangering the back through stretching too far (and I agree the smaller cuts are much quicker and easier to make on a saw bench) , is go for a vertical arrangement, keep the guide rail static (and vertical) and to move the wood. I don’t think the Festool rail and saw would work well for this sort of vertical jig at all and another sort of guide rail and saw would be better suited and probably along the lines of the vertical saw Steve Maskery put in his excellent article.
Of course, having already got the Festool saw and guide rail it was most tempting to see that as the basis for a panel cutting jig. Well thinking about all this is almost as much fun and actually making something, so thanks for posting the challenge, but I will have to sit back and see if John can make anything more of it. I’ve still got to sort out a way I’m going to use to handle the initial cutting of 8 x4’s, but I’ve still got the article on the home brewed vertical saw somewhere and I will give more thought to this solution. For now though its still likely to be the big heave onto saw benches, measure, clamp, measure, and cut on tiptoes.
