No skills
Hi all, bit of a ramble but bear with me..
I've got an old makita sliding mitre saw thats fallen into bad repair, I've got it sitting on a shelf at work doing nothing and having to cut stuff up by hand or skill saw at home
The main reason its hiding at work is the repeat visits the local thieving scrotes make on my garage - but thats a story for another day. So I'm getting the arse ache with it all and want to get this once nice piece of kit sorted and fit for use again.
Its got a bolt/handle missing that secures the compound angle at the rear of the saw - not a problem I can make something for this. One of the adjustment bolts has sheared off in the rear of the pivot assembly, hopefully I can drill and extract it and sort a replacement without too much hair pulling, lastly theres some corrosion to sort out as well (still supprising smooth action considering!).
Once I have all that done I will have a nice saw again BUT it will be completely out of adjustment and not even close to cutting square - so has anybody got any tips or advice on hows best to setup something like this? Obviously owners manual is a good start and I'll see if I can find one but I'm sure its not as easy as all that
