OPJ
Another factor worth bearing in mind is the wastage required when working with solid timber. As an example; some yards I know of will happily machine 5ft³ of timber for you and only charge you for that amount, even if they end up using, say, 8ft³ (losing 3ft³ to defects and damaged boards, etc.). You'd definitely have to start buying (and storing!) your timber in bulk. But, even then, you'd have to look at how feasible it is to you, particularly when starting out.
Brad makes a very good point in that the end user would presumably have all the other tools to do the job. Therefore, you'd possibly be looking to target the enthusiasts or 'hand tool galoots'... :wink:
Standard PAR is actually very usable although, the quality of the machining can very from one supplier to another. If you only need relatively short lengths and can cut out the snipe and any damage from the forklift (!), it can save a lot of time. Some people are too fussy! I don't think price is as much of an issue when it would probably cost you a similar amount to do all that machining yourself.
