Myford Planer Restoration
I dug mine out of storage last year and cleaned it up, the way to get the bearing blocks out is so simple, you take out the grease nipple each end of the spindle and replace with a bolt once you have undone the grub screws you can pull them out.
I hope this helps someone doing the same restore as once you have it running it is a fine planer to use.
I did a write-up see below:
I read on a UKW post about a guy that had a Myford PR11 planer and he used it most days I remembered many years ago I had one that I tucked away under the bench in the workshop, so dug it out, when it was stored away I had taken out the cutters and adjusters and put them in a box along with 2 sets of spare blades, spanner, grease gun, but the spindle lock had gone missing (good memory). I found over the years it had gained some rust mostly on the shafts, the beds and fence had had lots of wax over the years and this had held off the rust.
So started my job to strip down and bring it back into use, first I got hold of some rust eater to put the shafts and spindle to soak in overnight.
Next thing I stripped down the bearings and spindle, very simple job to do take out the grease nipple each end get a strip of metal drill a hole in it and poke a 0BA bolt through screw into bearing block and pull but first remembering to undue the grub screws, found something interesting in the spindle when you take out the bearing blocks there is a baffle plate with a hole through to push out the opposite bearing case, the centre of the spindle is full of old hard grease when it was greased in the past the grease went through this hole and not much of if any went into the bearings so will make up a bar to be a sliding fit inside the spindle so when you grease them the grease will come back into the bearings, (Myford never thought of that one) will replace with new bearings later, cleaned out the old grease from within the spindle put it into soak.
Then took off the two beds and started cleaning / rubbing down the main casting, day 2 cleaned the two beds and fence, the screws holding the two roller extensions need replacing rusted bad so will make new ones will also replace the spindle lock at the same time.
Took parts out of cleaner they came out well no rust at all so washed off and stored till ready to re-fit.
Well had a good day at the lathe made four 1/4" BSF bolts and the spindle lock all in stainless steel, turned a bar in hard plastic to part fill the void in the spindle, now when you grease it hits the end of the bar and comes back into the bearing rollers, job well done!!!
Paint came today (www.paragonpaints.co.uk BS2660-5-059/0.5L,Sky) so was able to put first coat on perfect match, will leave a few days to harden then finish coat.
When the paint has hardened off I will re-wax the beds and fence I remembered I used to run the heat gun over the cast and applied the wax whilst still warm and you get some wax melt into the cast and it lasted longer.
Well the new bearings and belt came they are now fitted, and I took some more images before moving out the way to get the stand and motor sorted next.
Went digging in the old shed for the stand and motor no go on this at all completely rotted and I don't like the look of the old Hover motor as well so back to the drawing board.
I was thinking of making an aluminium frame for the base but I found I had a frame from an old plotter that is better made than aluminium, now I need to locate a motor and starter.
Excellent thanks. As I can barely use a chisel I'm pretty much snookered. How would I get one made? Has anyone any advice please.
just get a long screw of the correct size and a nut, washer and a suitable spacer. to be honest if you have a problem with that then you should not be taking it apart in the first place.
It's a cross I bear, but I tend to over think the problem and.... I learn best by watching. We can't all be good at everything. You put up a post [sincere thanks it was fascinating] with a video saying "simple when you know how" so I set about finding a toolmaker to make the tool in the video [which I have done] and all I needed was a long screw of the correct size and a nut, washer and a suitable spacer all along.
I have one of these planers but it did not come with the leaf spring and it makes me nervous hearing about not using without one. Does anyone have any drawings, images and dimensions of what is required so I can make one?
Thanks for any help and advice..
