Lathe User
Morning. I would appreciate some advice on the following please.
The Dewhurst & Partner Ltd of Hounslow TypeA Forward Off Reverse switch from about 1970
This switch was fitted to early Myford ML10 as standard equipment to control a single phase motor using 4 cables + earth between the two. I have a short!
I am fixing the lathe to sell. during its decades of storage I am told a baulk of timber fell on it bending the top slide and cross slide feeds. These have now been replaced with new Myford parts.
The above control had its tin casing bruised. On taking it off I was more than a little surprised that the centre stem of the control pivots on the bottom plate. Removing the front cover dislodged the stem and parts of the switching stem just fell on the floor.
Now the question is - have I re- assembled it right or is it the connection to the motor I have wrong - or both?
A diagram would be brilliant.
A second question is - is there a modest modern equivalent you could guarantee will do the job. What exactly?
