Progress has been slow(ish) lately. Depending on the weather I've divided my time between fitting the two end windows and cutting and fitting corrugated metal to one side of the roof.
The two windows are now in - making the end of the building subject to the worst of the weather - well - weatherproof!
The difference this has made inside is remarkable and I think we'll have a nice environment to spend lazy days in eventually.
The roof covering is pre-used wriggly tin sheets that I've cut down in order to lose the nail holes. This, in effect, becomes a wriggly tin tiled roof and involves a lot of cutting and a lot of fixing. And a whole load of head scratching when what I thought was a standard profile turns out to be at least three subtly different profiles that will only really match up on the edges. It's certainly kept me fit climbing up and down the ladder trying different sheets for size!
The main problem area is where four sheets overlap on their corners but I found that sitting on the join while fixing the Tek screws works a treat! We had a glorious day weather-wise today so I managed to finish the largest side of the roof quite quickly. Just the other side to get on with now!
We like the patchwork effect and it will be a shame to cover it in bitumen paint but it needs to be sealed. Shame.
Before I started today I remembered to walk up the lane and take a picture to show how the offset gable and long, shallow slope on one side of the roof was intended to mimic the lie of the land - I think it works and we're very pleased with how unobtrusive the building is generally.
I've had a quick look at the remaining roof sheets I've got to cut up and there aren't enough to finish the job so I've put the word out locally that I'm looking for more. I'll probably end up with far more than I need now!
