TornUp
Hi all,
So, it has been a long time coming, but finally, my workshop is on its way!
In short, the base is going to be a raised base covered in 18mm OSB with a 10x13ft metal shed on top!
Because it is a metal shed the inside is going to be insulated and all walls will be boarded..
Thinking about going with a 2 full length benches down each side configuration with a mobile bandsaw/table saw stored at the far end..
Other bench tools are going to be on a “side in module” system in which the will be stored under the bench then slid into a “dock” built into the top of one of the benches when required, Except the pillar drill.
It should be quite a fast initial build log, my timeline is as follows:
Today/tomorrow – ground work.
Saturday – finalise groundwork and receave Wickes order of materials for the base.
Sunday – finalising any loose ends, and planning / dry run of base “pillar”
Monday – build the pillars
Tuesday – base woodwork and weather treatment of materials.
Wednesday – finalise base woodwork and position onto block work pillars
Thursday – installation of the floor sheet material
Friday – shed construction
Saturday – shed construction
Sunday – finalise last min bits
Monday – relax and enjoy my newly build(but empty) workshop!
The rest of the construction will continue from there on a slower monthly basis.
If anyone has any questions or comments about something I might have overlooked, let me know! Would rather fix it before it becomes a pain in the buttocks to access!
Photos to follow!
Tom!
Photos to follow!
Tom!
